Brakemanbobsmith
Almost ready for speed run.
Spool in an shimmed up.
Still working it out, RPM front bumper has to go! Causing front end to lift an backflip the car at about 80mph.Almost ready for speed run.
Spool in an shimmed up.View attachment 10419
The spool eliminates the center differential, makes it a direct drive from motor to front and rear differentials.Can you explain this a bit more or shoot me message?
What kind of jeep you running yellowjeepguy? I have a modified XJCan you explain this a bit more or shoot me message?
I so look forward to seeing more of this build and videos of your speed runs. This thing sounds like it's going to be amazing.Along with the spool we are in the process of installing a 1/5th scale Momba monster XL ESC and KillMode Capacitor 4 pack
Will post pictures as build progresses Woodie.I so look forward to seeing more of this build and videos of your speed runs. This thing sounds like it's going to be amazing.
No this is strictly for on road speed runsI assume you can't bash on that set up? 2002 tj fully cloaked!
Im really not sure what ratio combos will work with spool were running 34 spur 34 pinion and that pretty much maxed out our spool, we did rum a 22 pinion and 46 spur once an that to was getting close to max?Can i buy spool somewhere? I mostly want it for more gearing options. I want higher gear ratio but i don't have skills or tools to make spool. Whats highest gear ratio that you can buy parts and bolt on it?
Henridrivefast yea you can buy one prebuilt from a fellow on youtube that gose by the name Typhon he builds them for people.Can i buy spool somewhere? I mostly want it for more gearing options. I want higher gear ratio but i don't have skills or tools to make spool. Whats highest gear ratio that you can buy parts and bolt on it?
Will be working on it tonight.
Quick run down of mods to TyphonAlmost ready for speed run.
Run down of modifications to TyphonAlmost ready for speed run.
View attachment 10608 spool built and installed withAlmost ready for speed run.
Spool in Poseidon 2200kv motor installed.
Momba Monster ESC mounting plate installed (made from type 2 titanium)
Momba Monster XL fitted an mounting holes drilled
Spool,motor, cooling fan, ESC, Cap pack all mocked into place.
Ready to solder up wiring an route the wiring.
Wing modified.
Getting close, hopefully test runs bythis coming Saturday.
Waiting on new set of wheels due in today.
