Spool and pinion gear size.
Freedomfarmer420
  1. Outcast 8s
  2. Typhon 6s
Ok I have a stretched typhon gt conversion build. It has a mojave chassis scorched spool and drive shaft whit loktek motor mount. I have the xlx 2 esc and 2028 1700kv motor. What size gear should I go with for spool. I don't have a top speed in mind but I'd like to get upwards of 150 eventually.
Freedomfarmer420
  1. Outcast 8s
  2. Typhon 6s
Im 34/34 spool on 8s 1650 🤣still trying to control it on 4s with smc 7200 lipo with grp or hoons tires
Nice, I already have one 34 pinion just need one more. Definitely gonna have the same problem you have with controlling it. An outcast 8s is the only rc I have right now and haven't had it long so my top speed is probably 50 or 60 mph. Gonna start off slow on rubber tires till I get comfortable then when I start getting 120+ im gonna try and find cheap foam tires and learn to drive on them till im comfortable then ramp up the speeds. I have sum supposed to be good foam tires but don't wanna use them till I know what im doin
Freedomfarmer420
  1. Outcast 8s
  2. Typhon 6s
well 32 34 won't reach gonna get a 34 and a few other gears to try till i find something that does fit.
real_name_hidden
Bash/Break/Fix/REPEAT 🤣
Hospitality Award
Missouri/Illinois
  1. Limitless
Yes to both, maybe a 34 34 will work but gonna start with a higher tooth gear till I learn how to control the car
It’s been a while. Since I had a rotolock. But that doesn’t seem right. But with my PPS I’m able to use 27t with a 34t so I’m wondering if it’s being adjusted right. I’m not doubting you at all. So don’t take any offense. I’m just trying to wrap my head around it 🤞
Freedomfarmer420
  1. Outcast 8s
  2. Typhon 6s
No offense what so ever. I have no problem admitting i don't know what im doin. Ill take better pics tomorrow to show you how I got everything
I zoomed in a pic
Freedomfarmer420
  1. Outcast 8s
  2. Typhon 6s
Here's a close up
