Felony Spool gear for drag racing
Tara
  1. Felony
  2. Senton 3s
What spool gear in 8s felony should I run for drag racing? Has anyone changed theirs?
Has the 27T speed pinion, 1650 1717kv castle system.
What tires are you running?
I am either running the gone bananas or bsr xx pink.
Have you changed your F/R diffs? They are different gear ratios in the Felony and using a center spool along with the same size tires on all four corners is going to have a bad outcome. You will find the car will over drive the front tires. You can simply get the same GP5 ring and pinion for the rear as you have in the front to fix the issue.
