I got spool gear yesterday and it's a stk spool and gear, recommendations for what size pinion would be appreciated, I have a bunch of pinion gears just not sure what size I should use
This is my favorite as it allows you to factor in tire ballooning. If you have any questions what you need to plug in where, hit me up.I do not have a site that I go on
If your Limitless is V1, enter 3.3 for diff, if it's a V2 enter 2.8, 1 for transmission, 1 for additional gear ratio. For battery voltage enter however many cells you're running and start with 3.7V/cell for starters. For KV rating enter 80% of your motor's KV rating (this is to account for load), tire diameter is 3.93 if you're running Hoons, 3.85 if you're on GRPs, for balloon enter 0.1. Current draw and motor resistance aren't relevant for speed calculation. Obviously enter spur and pinion as installed. Hit calculate and that should get you in the ballpark. Some of the fine tweaking comes afterwards by analyzing data logs if you have a Castle ESC. There you can check what your voltage is during WOT. But let's take it one step at a time. This should give you a realistic point to start from.I'm not to sure what to enter as diff and trans gear ratios
