Kraton SPRING KRATON
DenisNew72
Россия
Hello dear friends, I am from Russia. Recently I had a crash on the craton , At high speed, cut into the curb left side --- the result was a broken front shock absorber . And immediately asked the question: REPLACE STOCK SPRINGS !! because native spring flaccid/soft can not cope with the power and weight of Kraton..... Friends tell me/help please advise a good strong STIFF SPRINGS FOR the KRATON (front and rear) ??? what to buy ? and what manufacturer ..... ?? ( preferably links from America) a Few pictures of the farm
вот ещё фотки)
I replaced my springs with Techno orange, these are quite a bit stiffer than stock. You will also want to change your shock oil, I recommend 60w up front, 70w in rear. I like this setup a lot. Handles jumps a lot better and doesn't bottom out as easily. Rides a bit taller and doesn't squat as much when turning and braking. There is some information here, with a Tekno spring chart and part numbers: https://arrmaforum.com/threads/kraton-shock-springs.491/
[Цитата="chalmene, должность: 14141, член: 739"]я заменил пружины Техно оранжевый, это совсем немного жестче, чем стоковые. Вы также хотите, чтобы изменить свой вид масла, рекомендую впереди 60Вт, 70вт в тылу. Мне нравится эта установка много. Ручки прыгает намного лучше, а не снизу, как легко. Едет немного выше и не приседать столько, при повороте и торможении. Есть еще вот какая информация, с Текно весенний график и номера детали: https://arrmaforum.com/threads/kraton-shock-springs.491/[/Цитата]
You put the TEKNO in the orange circle ? (on the front and on the back? the same ?)
I am using the orange springs: TKR6083 in rear, and TKR6093 in front.
And the damper shaft can be any length to put ?
You will not have to replace any shafts. The Tekno springs will fit directly on your current shocks, and you will have a lot more adjustment because the Tekno springs are a bit longer.
The last question ))) Please tell me the absorber rods of the craton of the same length ? ( the same length of the absorber rods front and rear ?)
The front and rear rods are different lengths, the front is shorter than rear. Here are your part numbers per the manual: AR330195 for the front, AR330251 for the rear. Hope that helps.
edit:
I would also order AR330203 ARRMA Shock Part Set Compostite (2), as these parts often need to be replaced with shock damage.
[Цитата="chalmene, должность: 14151, член: 739"]передние и задние стержни разной длины, спереди короче, чем сзади. Вот ваши номера детали в инструкции: AR330195 для фронта, AR330251 на задней панели. Надеюсь, что помогает.
редактировать:
Я хотел заказать AR330203 ARRMA шок набор Compostite (2), так как эти детали часто нуждаются в замене с током повреждения.[/Цитата]
Thank you dear friend , and the other guys of the forum , you helped me a lot ) And now I'm smart mug will go to tell our Russian forum ARMA knowledge ) Thank you very much chalmene )
редактировать:
You're welcome friend, hope your Kraton is back together and running better soon! Enjoy!
