- Birmingham, UK
- 4x4-Mega
- Mojave EXB
- Outcast 6s
- Typhon 3s
You're welcome buddy, let us know how you get on.Thanks
Just ordered the one if Jenny's rcYou're welcome buddy, let us know how you get on.
And I think I'm gonna buy a metal spur gearJust ordered the one if Jenny's rc
Spur assembly's cost so much almost as much as my motor and escJust ordered the one if Jenny's rc
Sheesh whatSheesh dude
Ok but will it work have the time people don't get back to meSheesh what
I need to make sure this will workSheesh what
You only need 1 more slipper pad if stickng with plastic ones. 3 metal ones on the metal spur, 4 plastic ones on the metal spurThat's for the MEGA version you need the 57t for the 4x4/3s rig and yes you'll need 1 more slipper pad (4 total) here's what you want https://www.amainhobbies.com/hot-ra...eel-0.8mod-spur-gear-57t-hrastff257n/p1232528
ok so is it metalthat's the 17t for the mega 13t is for the blx
what diff case do i haveThat will work for a V2 MEGA. But again, what are you trying to do? You mentioned something about buying a V3 3S Slipper assembly in another thread. The V3 slipper assembly has a nut at the end that holds the assembly together which necessitates the use of the shorter input (ARA311031). However, it is a 13T 1.35 MOD input gear which needs to be used with the 37T diff case (AR310872)
The 17T input gear you mentioned above is meant to be used with the 49T diff case (AR310802) that came with the V2 MEGAs
so the one i showed you will work on a v2 granite and its metalI can't guess what diff case you have as both the 37T and 49T work in the MEGA/BLX cars. If you have a V2 MEGA that is stock from the factory, then it would be a 49T diff case. Many of your questions can be answered by referring to the exploded view diagrams: https://www.arrma-rc.com/pdf/exploded-views/ARA102714T1.pdf
yepOh s#%t!!! Here comes about 8 more threads about the diff case. Lol
