blank
Hey, it's me again, the person with the mesh problems. I messed up the mesh again, and the gear is pretty much non-existent. I'm thinking of getting a steel spur gear. Should I?
I've had my pinion come loose with the steel spur and nothing happened to either. Guaranteed a plastic spur would have gotten chewed up lolThe steel spur will destroy the pinion if the mesh is not set correctly. If setting the mesh is difficult get the fixed plate. Perfect mesh every time. https://www.arrma-rc.com/part/AR310874. It does limit the pinions to 13,15,20,&26.
Good bit cheaper than a steel spur and a replacement spur is $5 when it wears out.
