I already up grades to 3s and I just upgraded to a 17t pinion but I don't know what I would need to upgrade to a 0.8 model spur gear do I only need the spur gear or do I need a whole new slipper clutchThe v3 has 57t/0.8mod (32dp), the v2 has 9[1 from memory]t/48dp.
The old mega 48dp setup is in my experience very weak. I would sack it off and go for the decent 3s 57t setup (note you will need to change your pinion too). The metal spur gear is, AFAIK, only available in 57t.
If you have the old slipper clutch with the red plastic nut on it you will need the whole slipper assembly and a new 0.8 mod pinion.I already up grades to 3s and I just upgraded to a 17t pinion but I don't know what I would need to upgrade to a 0.8 model spur gear do I only need the spur gear or do I need a whole new slipper clutch
How much moneyIf you have the old slipper clutch with the red plastic nut on it you will need the whole slipper assembly and a new 0.8 mod pinion.
www.google.comHow much money
