Is there a steel spur gear available at all for the Typhon Mega or can another slipper assembly be used?
Slipper assembly of the 3s or 4s line maybe hot racing makes a steel spur for mega but i really doubtIs there a steel spur gear available at all for the Typhon Mega or can another slipper assembly be used?
The 3s spurs have bigger teeth (32p/0.8mod in size) so you need to change the pinion on the mega to match and when you do that you will need the 3s motor mount or optional adjustable motor mount because the preset mounting holes of the mega will no longer align.I have dug deep into this and haven't found anything yet and I don't believe HR has one either..
Would the 3s slipper assembly fit the Mega?
