jmacrc13
  2. Senton 6s
Just upgraded to brushless in my Arrma granite with a Sidewinder setup. Everything programmed but sometimes when I'm running it there is a delay. I hit the gas and it will run and stall run and stall then take off like nothing is wrong
Double check your battery connectors and then look at the esc low voltage cutoff may be that it's set to high. What kind of connections does the esc have? I never use anything but deans for my trucks!
Your packs may be too low C. I'm not sure if the sidewinder has punch settings, but you may be able to dial that back so it isn't trying to pull so much current on take off. My MMX has punch settings and another setting that you can adjust how much burst current it uses overall for less than super high performance packs.
It's shown as the "Start Power":
I had mine on medium and the punch at 70%. With my older tired 60c packs, it would hesitate just a fraction of a second off the line, but with it adjusted to low/75% they seem to work fine now.
