BulletRCs_NZ
- Martinborough, New Zealand
- BigRock 4x4
- Senton 3s
- Vorteks
Pictures speak louder than words
Good to know. Its been so dang wet here with the rain before the hurricane and all the rain after, ive barely ran mine at all. I think Im going to get one ordered for my Senton that takes the most abuse, as I am thinking about doing a 4s build on it, and turn it into a 4s Monster Senton, and throw some heavy duty style parts at it.
Also, finally watched your video on this thread and WOW is that your property ? If so that looks like Heaven for off road RC fun.
I know it's very hard to believe, but lifting the remote when jumping doesn't make it jump higher. (I do it all the time too!)Pictures speak louder than words
Looks like a fun spot to run in!
You're right. Raising your remote only gets you that last 5 degrees of rotation when doing backflips.
You have put marine grease inside the diff or around it?Update #001001
Had some diff clicking yesterday so tore down the rear steel diff ... and it was in perfect condition. Dunno how many packs but a lot and no visible wear to the crown or input gears. The internal gears also showed no wear but the oil level was pretty low. I packed that sucker full of marine grease (because it's all I've got) and reassembled it all.
So the clicking must be from the front diff. Yep a worn out input gear so replaced that
The BR now runs perfectly and the rear diff feels a lot more 'locked' with all that grease in it. It's not really locked but it sure seems a lot more direct.
If you've put it inside im shure it is almost locked.
Update #001001
@BulletRCs_NZ Hi, recently the front input gear in my big rock decided to shred half of itself. I was wondering what the metal diff you are using is and is it still holding up well? Anything else I need to go along with it? Thank you.
