ajdragon
- Raider
Hi
Well it would seem that the newer Arrma 1/10th RC's still have the same problem where part of the steering assemble hits part of the servo cover. As you can see in the pictures below this is where the parts were hitting and what i had to do inorder to fix this problem. It's not as bad as it was in the older ver.'s but it still puts a strain on the servo saver and could possibly brake the pin that holds the servo saver together. So you may want to take a look at yours and see if you have the same problem.
I went a little over board on the servo horn side but not the servo saver side.
Defiantly to much on the servo horn side
