On the fireteam, using the stock transmitter you must disconnect/unplug the brake servo to be able to use the +\- switch to adjust the end points.
Being new to the hobby, I was unaware of this and struggled to find any fireteam specific instructions and it left me scratching my head. For the stock SLT3 transmitter the process that worked for me is:
Disconnect RC battery
Remove the cover on the receiver
Unplug the rear brake (aux)
Ensure the steering sensitivity knob is at 100% (turned all the way to the right)
Connect RC battery
Power on the transmitter (to ensure it is bound to the RC)
Power on the RC
Power off the transmitter
Turn the transmitter wheel full lock right and hold
Engage full brake/reverse and hold
(Hold both steering and brake while powering on the transmitter to enter programming mode)
Transmitter should blink red, release throttle and steering
This engages the steering end point setting
Turn full lock right and hold, use the +/- switch to set the travel
Release the steering wheel to save the end point
Turn full lock left and hold, use the +/- switch to set the travel
Power off the transmitter to save settings
Power on the transmitter and verify The end points were saved
Power everything off, disconnect the battery and replace the brake servo plug and compartment cover
I hope this helps any newcomers that faced the same trouble I did finding help, as this procedure is not in the instruction manual that comes with the fireteam.
Connect RC battery
Power on the RC
