Clydesdale
- Granite
I have put 2 new servos in my granite. when i turn the wheel to turn it it wont move. But if i use my trim dial it will turn fine any help would b grateful thanks
We have a limitless section?This is the limitless section, you’d probably get better results posting in the granite section.
https://www.arrmaforum.com/forums/arrma-4x4/?prefix_id=66
It was under the 6s limitless tab... then he changed it to senton ?View attachment 79715
I'll move this to the right spot.
Also merged both of your threads.
But I would have to agree with @Orebro80, if 2 different servos are doing the same thing, and the wheel on the transmitter doesn't turn the wheels but the trim knob does, then that really only leaves the transmitter as the problem. The potentiometer or whatever it is called might have gone bad. There is a 2 year warranty so you can contact Horizon Hobbies and they will help you out.
Sorry my apologies sir the facepalm wasn't for you it was for the other guy, because not only was it in the wrong section but he had the wrong vehicle too.It was under the 6s limitless tab... then he changed it to senton ?
I was only trying to help him get a better response...
EXCUSE ME!!
