Just Bash It Rc, GKA and Voltage all make beefier aftermarket ones. Not sure where you are though, but in North America, anyone of these three would have exactly what you need. Btw, I've only ever bent one, and I replaced it with a new stock part. I bend everything, but that part seems to be my kryptonite.Any good upgrades? Stock one keeps bending.
Yeah I already have a original one coming. I bent my current one back for the second time. And, I'm in north americaJust Bash It Rc, GKA and Voltage all make beefier aftermarket ones. Not sure where you are though, but in North America, anyone of these three would have exactly what you need. Btw, I've only ever bent one, and I replaced it with a new stock part. I bend everything, but that part seems to be my kryptonite.
Has anyone used this yet?
https://www.rcracinginnovations.com/store/p784/Arrma_Carbon_Fiber_Steering_Rack_-_ARA340060.html
I'm in the same boat trying to find one bent two broke one factory already voltage and jbirc are out of stock and other options are from UK or Canada so don't want to wait for shipping.
I would like a voltage hobbies one but again out of stock does anyone know when they would be back
I'm running the Scorched Ti ones..??? no problems so far...
YESSIR, my original KRATON that I lost in an accidental had the Hot Racing Spindles on all 4 corners, I never changed the steering Bellcrank or Ackerman plate but I was planning on it. Really that was the only thing left besides I was going to install the GPM 6mm(5mm stock) axle's, which are CVD'S only, no dogbones to fly out anymore and most likely no more bending. I had the Hot Racing: motor mount, both chassis braces, servo mount, rear inside section of the diff housing, wing mount (I'm going with GPM on that this time because it comes with a alloy wheelie bar and solid wheels), and spindles. I had GPM: steering top plate, front end/rear upper suspension mount, and shock towers and can't complain about any of the parts. It took no telling how many bad landings on the front shock tower to bend it a little, but it took a 5lb sledgehammer to straighten. Hope this helps, the Hot Racing Spindles are probably the best with their carbon fiber steering linkage mounts that are replaceable if one were too break so no fear of bending like Integy or GPM, which is possible but not very likely unless you're Rich DuperbashProbably the single most helpful comment I have received on here and I appreciate it! Do you have experience with any of them?
Thanks for the update I have been seeing a few ti ones one ampedrc I believe but I have never ordered from out of country not sure of times and cost offset etc..update on this part. Don't waste your money. broke it on the third battery pack. looks nice, does not hold up to bashing. still waiting on jbi or voltage to come in stock now.
Waiting on that one to show up for my outcast. Wish they changed it a bit so you could run bearings vs shoulder bushings on it.I'm running the Scorched Ti ones..??? no problems so far...
