Kraton Steering Server Mount Replacement
tigerljj1
Upland, CA
Hi forum. Does anyone have a video or pics on how to replace stock steering server mount? Researched the web and YouTube but none have step-by-step instructions.
Thank you!
Thank you!
You take four bolts out of the bottom that hold the stock mount to the chassis. Take the servo horn off. Remove the four bolts holding the servo to the stock mount. Repeat backwards for new mount.
Tiger, I have to apologize because I was wrong. You more than likely will have to completely unplug the servo from the receiver, as there is no other way to get the servo through the mount. I found this out last night when replacing the mount. See the pic.
You will also need to remove the ESC tray/mount as the stock servo wires are routed under there.
Be very watchful how you route the new wires. Don't mean to point out the obvious but I was real careful with wires when I installed the Voltage Hobbies mount but weeks later I put all new bearings and shimmed the diffs and I remember slamming it all back together because it was memorial weekend and relatives had their cars ready and waiting on me. Didn't have any problems right away then last week I landed a jump and lost steering. As I got closer she was rolling smoke. Scared the hell out of me I thought it was a lipo. I found one pinched servo wire.
