Kraton Steering servo
Jsroberts
Colorado
Savox servo 145.8 oz-inch torque
After market is it enough to use in The Kraton/ Stock one was over 200 ! My learning curve on this is growing with every mistake ! SC-0252 savox #
Josh nortz
Farmington NY
No do not buy a servo with less torque... you want the same or more, alot of people run savox 1256sg I belive it has 277ozin an improvement over stock. I run a 1231sg that has 444ozin but taller than stock servo by quite a bit... 277ozin should be fine for just bashing around.
Jsroberts
Colorado
Thank you, I had a taller servo with about 225oz-in but did not like how it sat inside stock plastic servo holder! Did you use spacers or replace how servo connected
GT1
Rockford IL
The RTR orange servo is a lie, it is slow and weak. There is no way it is a 15kg servo.
A 1256TG should hold up fine. It was designed as a MT servo. I run one in my Typhon and it holds up well for track work.
Vanning
I don't have an issue with the stock one...it steers fine ? I may have pushed more voltage to it with my ESC.
The stock servo is a 7.2 volt servo...208oz at 7.2 volts. However, I think the stock ESC only has a 6 volt BEC ?
Mine steers fine with the stock servo....it hasn't given up yet. Once it does or if it ever does...I'll look into a Savox....I have good luck with them.
Josh nortz
Farmington NY
It's 15 kg at 7.4 volts... kraton puts out 6.0v so yes it is not at full potential...
Ole Fart51
Louisiana
  2. Talion
Bought the Savox 1231, love the torque and speed. I find it too tall and putting lots of stress on steering link because I had to use a spacer between the link. I did a little more research and found the 1270. More torque and speed and normal profile. Ordering it tomorrow
Jsroberts
Colorado
That is very true I found that out! I need a booster right?
Velodromed
One to turn, two to burn.
San Antonio, TX
  1. BigRock 4x4
  2. Granite
  3. Kraton 6s
  4. Kraton 4s
  5. Notorious
  6. Outcast 4s
  7. Vorteks
  8. Voltage
  9. Infraction 4x4
6 years old…
SrC
RC is a lifestyle choice
Hospitality Award
Queens, NYC
  1. Fireteam
  2. Infraction
  3. Limitless
  4. Kraton 6s
  5. Mojave
  6. Notorious
  7. Outcast 6s
  8. Typhon TLR
Yes old thread that has some relevance today....perhaps???:giggle::ROFLMAO:
35 kg (minimum) torque servos best for a 6s rig. Even a 4x4 basher rig.
DS3235 on the cheap, if need be. AMZ.
