steveoarrma517 V2 talion times
Wisconsin
  1. Felony
  2. Mojave EXB
  3. Talion
  4. Talion EXB
V2 talion:: rc juice hobby star system,2000kv ,150 amp esc...castle fan,hot racing braces,steel assy servo mount,eddy bearings,teckno springs/shock socks,HR center diff sliding mount,and m2cracing center mount coming.next tear down to add heavy duty diff cases,maybe aluminum steering hubs if they have larger bearings to benefit from.
V2 talion:: rc juice hobby star system,2000kv ,150 amp esc...castle fan,hot racing braces,steel assy servo mount,eddy bearings,teckno springs/shock socks,HR center diff sliding mount,and m2cracing center mount coming.next tear down to add heavy duty diff cases,maybe aluminum steering hubs if they have larger bearings to benefit from.View attachment 74440
I would go with the PPS motor mount over the M2C only because it's easier to adjust the gear mesh. https://practicalproto.com/collections/frontpage/products/v4mount
You will also need this being as how you are coming from a V2. https://practicalproto.com/collections/frontpage/products/arrma-v4-6s-blx-differential-mount
Thanks,m2c says can use arrma plastic top plate or may make one or try another mount.Have hot racing stuff coming too.
The PPS mount is well worth it, I have used the Hot Racing and the M2C, and nothing against M2C but the design of the PPS mount just seals the deal.
