Hi folks,
Dumb question. I am just now assembling my Limitless. I am using the Castle 1717-1650 motor. I am having difficulty inserting the motor (with stock insert attached) into the stock motor mount. Doesn't seem to fit. It seems the insert doesn't slide in. Also if stock slide works, which one?
Do I need the PPS insert? Forgive me for asking this question.
Best,
Jonathan
FOLLOW UP!
Ok, motor and stock mount/insert work. But the new problem is that there isn't adequate space/shaft length for the pinion set screw. What??
FOLLOW UP 2
I a small Armma pinion to work. My cheap Ebay pinion had a set screw that was a little too wide/long. Unfortunately the pinion I have in there is like a 19t.
What brands of pinions for Limitless have the necessary tolerance. Was looking for a 28-30t.
UPDATE. Found a Tekno RC 30t mod1 5.mm on Amazon. This brand is the one I'm using. JC
Thanks
Best,
Jonathan
FOLLOW UP!
FOLLOW UP 2
Thanks
