Xtremekhaos
- BigRock
Hey guy need a little help just brought a typhon 6s and wanna change tires but cant remove then .i removed the nut and they should just slide off .any tips on how to get them off ?
Sounds like a life learned lessen there.Just don't forget that it's hot now and put your thumbs on the hub after the heat!
And don't forget to introduce yourself in this thread:Hey guy need a little help just brought a typhon 6s and wanna change tires but cant remove then .i removed the nut and they should just slide off .any tips on how to get them off ?
That sounds like the fun way to do it! A lot less cussing too!I just removed all the nuts and took the car out for a run. After one wheel fell off I took it in and the others were now loosened. Hexes weren’t damaged either.
