- Typhon 3s
This is kind of weird. And sorry to bore you all with another one of these posts. But I’m seriously at a loss.
I have two 3S Typhons, one I’ve been working on for my son. Both have stock motors with VXB Bearings swapped in. Both have been fine until tonight.
My son’s was making a screeching sound at full throttle so I assumed the slipper was loose. That was fine so I opened the diff cases. Normal. I run the motor by itself (no pinion, no heatsink, no motor mount, etc.) and it sounds fine but it gets crazy hot in my hand almost immediately. Within ~10 seconds of full throttle I can’t touch it without pain. So I get the temp gun out, reassemble everything, and run it. After 5 minutes on 3S around my street it’s ~210F at the cap.
Sheesh. So, I take the motor out again, disassemble. Clean inside. Everything looks fine, bearings are not seized and are smooth. Reassemble and run it, same. For good measure I swap the bearings with brand new Jim’s bearings - still the same.
Thoughts? I took my good motor and swapped it into his car, all is well, so I have no idea how else to troubleshoot.
Thanks all.
The above picture isn’t illustrating what came out of the motor - that’s pieces from my freshly asphalted street that fell out of the body. And yes motor’s plastic wire harness broke a while back as you can see.
Thanks all.
