Wildman13
Hey all,
There are a ton of articles on storing Lipos I've found but none that cover doing so in a small RV (Travel Trailer). Traveling full time I have very limited options.
I will be using the outside plug to charge the Lipos, def NOT in the RV.
I need to make my set up the safest possible. I will have 4 gensacearespammers 5000mAh batteries that need to be stored. I will storage charge them before putting them away. It seems I should also store them separately as if one goes off it will ignite the others.
I've seen Ammo Cans, Batsafe nags etc. My places I can store them are. The only places I can think of to store them is:
- "Oven" which I read about but that sounds like a bad idea if you forget they are in there.
- Buy a metal storage box for the tongue of the RV but that is right behind two 30lb propane cylinders. $200-$300 fro the box plus the batsafe, bags etc. Not a cheap option.
- somewhere in the RV where it will definitely catch on fire if there is a fire or suffer smoke damage at the minimum with a bat safe etc.
- In the truck with us. Once again same result as the RV except now were trapped next to it if driving.
- Bed of the truck, we have a topper. But we have 2 expensive mountain bikes back there. Smoke won't bother them but it gets really hot back there as it's a black metal topper with no windows and I'm in Arizona right now.
Any suggestions are welcome.
TIA
TIA
