ARRMA-GET’M
xlx2-1100kv-Radiolink G6 - 1/5 Kraton
No aux wire being used
Nothing assigned to aux wire
PROBLEM:
Everything operates normal except for when decelerating. If I’m at let’s say 50% throttle and I suddenly lower the throttle to 25% throttle right away, the motor ALSO drops to 25% rapidly and it jerks the whole drivetrain instead of just coasting and rolling free until the motor takes over at that given lower rpm or speed. In order to avoid this, I have to either let the throttle go completely so it’sin neutral and the truck will roll/coast just fine. Also if let’s say I’m barely on the throttle and the truck is keeping, you can push or force the truck to roll and faster than that bcs it’s locked in that motor rpm. I’m NOT using any crawler mode nor any drag brake nothing and no aux. my sensor wire makes no difference used or not and it’s the proper one if you’re asking. It can’t be any of the parameters in the Radiolink G6 bcs this behavior existed before I changed the factory settings. Someone mentioned updating the firm on the radiolink to the newest but only one person EXOCAGED said his xlx2’s do the same thing to him, others say NO that’snit normal. I’ve exhausted all of the YouTube rc community trying to fix this. I even uploaded a video on my Chanel for those who want to try to solve this!
PROBLEM:
