Street sign skid plate + 3s/4s droop screw addition
neighborhater383ci
Albany Oregon
  1. Kraton 4s
  2. Senton 3s
Found that a street signs width is just about the same width as the 3s/4s chassis, and so I decided to go on ahead and cut it down and use it for a skid plate/brace and it works out great for adding droop screws by drilling holes in arms and forcing a screw to cut threads, only issue is the arms flexing if you run super stiff springs but I have a fix for that too if someone asks I’ll make a post about that. Also modified a 1/7 scale diffuser for the rear end just cause why not lol
Great job of repurposing the metal! 👍
Nice work
For the arms flexing you might be able to do something like what the race brands do:
Now that's what you call custom platinum 😁👍
Now IF he can only find a Nice Long Open road name Platinum St to speedrun on..
Would make this the perfect Custom Combo!!💥👊
Maybey when the city replaces the
missing platinum street sign 😁👍
Is your name neighbor hater because your stealing all the street signs🤔🤣🤣🤣
No lol although it would be fitting if that was the case it’s my trucks name
Nice work
I ended up getting some aluminum arms to fix that( yeah yeah I know it’s not ideal for the chassis but it’s braced enough now+ have two extras) with the plastic arms I drilled a hole through the arm long ways and pressed 6s hinge pins through the arms opposite to the side the shocks mount
