Thank you sir, you are too kind. And yeah, that was hard. I only got to 11 before my tongue cramped up.Top notch work Mr. B. She's as clean as the split that @LicketySplit licked (say that fast 37 times in a row...I DARE ya).
Don't forget the wingPretty much done. The front splitter will be replaced with a carbon splitter once the body goes on. Put on the battery straps, set the final alignment, and I think I‘ll call it groovy.
The wing will be incorporated into the body with the ubiquitous fins on the speed body, and will run with a ducktail on the basher body.Don't forget the wing
Ok don't forget the led lightsThe wing will be incorporated into the body with the ubiquitous fins on the speed body, and will run with a ducktail on the basher body.
I really like my Insta360 Go 2. It's small, uncomplicated and does a max resolution of 2560x1440. It's easy to mount anywhere and there aren't a thousand settings. It's almost point and click. And at $300 it's not outrageously expensive. Might be worth a look.Just as soon as I figure that out and get a GoPro or something. Outside of the handheld recording devices of yore I’m a bit of a Luddite. Any recommendations?
I appreciate that, I’ll check it out. As long as it works with iOS it sounds great!I really like my Insta360 Go 2. It's small, uncomplicated and does a max resolution of 2560x1440. It's easy to mount anywhere and there aren't a thousand settings. It's almost point and click. And at $300 it's not outrageously expensive. Might be worth a look.
10-4, roger that. It is iOS compatible.I appreciate that, I’ll check it out. As long as it works with iOS it sounds great!
I looked at the reviews, the most negative was recording length when out of the case, or overheating when it is. That and poor audio, but that doesn’t concern me much unless the audio is just outright indecipherable. Yours sounds fine in your videos. Any thoughts?10-4, roger that. It is iOS compatible.
Thanks, Ron!That’s definitely tits McGee!!!!!!!
Thank you sir!Just beautiful what an awesome build.
