Drill holes in the arms, the closer it is to the wheel, the lower it will be.I put a set a Street fighter tires on my big rock and wondering if I could purchase a smaller stiffer shock set up that would be better on the road. I am really not looking to modifying my stock shocks as I will still use them for off-road
Not a bad ideaDrill holes in the arms, the closer it is to the wheel, the lower it will be.
If I drill the holes closer to the wheels want the suspension be softer?Drill holes in the arms, the closer it is to the wheel, the lower it will be.
You can add preload spacers to make it stiffer, or remove them to make it softer.Not a bad idea
