Big_Granite_Rock
- BigRock 4x4
- Granite
What is the best street tires for the Granite 3S. I'm looking to have the standard set for dirt and this set for asphalt.
Anything from proline works great.What is the best street tires for the Granite 3S. I'm looking to have the standard set for dirt and this set for asphalt.
Keep in mind you will need 12 mm hexes. Here is the ones I run on my granite.What is the best street tires for the Granite 3S. I'm looking to have the standard set for dirt and this set for asphalt.
Thank you for the information!! Very helpful.Anything from proline works great.
I'll post a link of proline street tires below.
Hope these help.
And btw, duratrax is also good, just not as high quality as proline. For what I do, bashing at the park, I prefer proline.
Here is the link to two of their street tires.
https://www.prolineracing.com/1-10-monster-truck-tires-street/
Link.
https://www.amazon.com/dp/B07GR5GCQB/ref=cm_sw_r_cp_apa_i_TSr.FbEKWED56
No problemThank you for the information!! Very helpful.
Thank you very much!!!!Duratrax have a 14mm Bandito MT tires that will fit perfectly:
https://www.amainhobbies.com/duratr...ck-tires-w-14mm-hex-black-2-dtxc5536/p1226528
You can consider also the ST version that is lower, if you prefer a lower stance:
https://www.amainhobbies.com/duratr...ck-tires-w-14mm-hex-black-2-dtxc5540/p1226532
Both belted and a direct fit.
I cant find a proline option that is the MT size, and also they are unbelted. also overpriced IMO
Thank you!!Yep Duratrax/Louise is what you will want. Proline are fine, but overpriced for what you get. Be careful with belted tires as they tend to be heavier. Always vent your tires to minimize ballooning.
