Innuendo26
- Typhon 6s
Hey peeps, I was seeing if you guys/gals can help me out with what scale speed run body to look for, for my stretched Typhon.
Figure out your wheelbase dimensions and pick one of theseHey peeps, I was seeing if you guys/gals can help me out with what scale speed run body to look for, for my stretched Typhon.
Thanks for responding but I still don't know what scale to buy or even my wheel base. But I like a lot of those bodies on that website.Figure out your wheelbase dimensions and pick one of these
https://deltaplastikusa.com/collections/speed-run-bodies
Do you know what chassis you’re trying to use?Thanks for responding but I still don't know what scale to buy or even my wheel base. But I like a lot of those bodies on that website.
I have the kraton chassisDo you know what chassis you’re trying to use?
I cannot find any body shells with that wheelbase for speed runsWheelbase measurement is taken from the center of the front wheel to the center of the back wheel.
Given you have a Kraton Chassis then your wheelbase is the same as a factory 6s Kraton. (377mm / 14.84")
Thanks brotha, most appreciated ?Your best bet is probably going to be running a 360mm body from Delta Plastiks
you will want 3mm or 4mm bodies for speeds over 100mph.
The rear of the body wont line up with the wheels but since we cut out the rear of the body for speed runs that shouldn't matter too much.
