Lockup1109
- BigRock
Whats up guys, new to the forum and wanted to share my project and quest to best 150 mph.
Started with a typhon buggy and modified the he'll out of it.
As it sits I have a custom wound insanely high KV tp power 4070 cm 40x107mm motor running 6s.
Gearing is 1.27:1 ratio. Yes it is geared higher than the magic 1:1 speed run ratios. Wanted to share some pics, running an XLX with no current limit.
Belted grp velocity and sweep racing gt2 tires. Kraton chassis, custom made body mounts and esc mount and diff mount. Locked spool so I can run pinion gears as spur gears, 8mm castle connectors for motor, 6.5mm for batteries, 11000uf custom cap pack im soldering in tomorrow. Limited shock down travel. Outcast rear wing. Havnt ran it stretched yet or with this motor, but I hit 112mph with a MUCH less powerful and lower kv (2200) motor over the weekend.
Running 2x revolectrix 5000mah 70c tested 3 cell batteries. Best batteries I have ever ran with the lowest resistance I've measured.
Will post up pics of the final outcome and speed run this Sunday.
