I very well may do this also to the truggied 6s Typhon I have.
It is for sure, I didn't think of that until you mentioned it.
It sounded good in my head though.
Yeah I was all excited about my new great idea and as soon as you mentioned it I was like duh' he's right I'm a dumbass.don't worry.. I once had some sort of the same idea.. Turned out.. I also invented an allready existing Arrma.. LOL!
The whole 6s range is all real close to each other..
Looks great. It's definitely not a Kraton. It's got shorter towers and shocks, plus a completely different dif set up. My question to @LibertyMKiii and @Mike-NLD (@jezzzy seems to have left the building) is, what rear body mounts did/could you use? Asking for a friend of course.
Rear. Front should require no changes. I already have a Kraton rear dogbone, and the new EXB chassis braces. All I need to find is some extend body mounts. I've seen many, but not sure if they are all custom or if there is something out there that works without modification.To mount the Typhon body on the streched chassis? Front or rear?
What are these? I’ve got my stretched talion I need to do this with.HR 53mm standoffs #RCL65301 (2 packs) is what I use
I think I used 4 spare droop screws to go from the plastic body mount to the HR standoff.
The kraton came with a large assortment of body mounts, does the typhon not jave this parts bag with it?Rear. Front should require no changes. I already have a Kraton rear dogbone, and the new EXB chassis braces. All I need to find is some extend body mounts. I've seen many, but not sure if they are all custom or if there is something out there that works without modification.
This is the best looking mod I've seen on a stretch job! Nice findHR 53mm standoffs #RCL65301 (2 packs) is what I use
My stretched Typhon roller I bought here in the classifieds came with 3D printed rear body mounts. I can print and mail you a set if you want. It’s literally $0.25 worth of material.Looks great. It's definitely not a Kraton. It's got shorter towers and shocks, plus a completely different dif set up. My question to @LibertyMKiii and @Mike-NLD (@jezzzy seems to have left the building) is, what rear body mounts did/could you use? Asking for a friend of course.
That would be awesome Jon.My stretched Typhon roller I bought here in the classifieds came with 3D printed rear body mounts. I can print and mail you a set if you want. It’s literally $0.25 worth of material.
I will print up a few sets. I print mine in TPU so it’s flexible. If you want something rigid like stock mounts, it will need to be injection molded or printed in Nylon, which I don’t have.That would be awesome Jon.
Can I get some for my talion too!?My stretched Typhon roller I bought here in the classifieds came with 3D printed rear body mounts. I can print and mail you a set if you want. It’s literally $0.25 worth of material.
