Bingy93
stripped the grub screw on a rear hub on my typhon , had too much dirt in there didn't clean it out well enough and stripped it. Any ideas to get it out ?
I actually just used one today to get a stripped hex screw out, just have to find the right one to fit and make sure it is kind of flat on the end so it reaches to bottom of hex hole, but worked like a champ and backed my screw right out. Before this I was taking a drill with a small bit and drilling in through the hex hole just deep enough to pop head off the grabbing end of threaded shaft and turning it out worked but pain in the butt.mini screw extractor......looks like a drill bit.....but threads are opposite...so it digs in while turning left.....gotta use the correct size
