OrangeDRAGON
I ran into a problem with the pinion gear, whoever built this car really tightened the crap out of the grub screw and/or used too much thread lock. While I was not using ball-hex drivers, I was using a quality set of metric Allen keys (not the kit crap keys) and just when I thought it broke the grub screw loose, instead it rounded it out. Now I'm trying to decide whether I'll be fine sticking with the 14t for a while (on 4s) or if I should break out the Dremel tool and get this one off to put on the 16t (which was my original intent) :/
EDIT: Well it looks like that idea won't work either. I can't remove the motor from the aluminum mount with the pinion installed and the grub is on the 'inside' of the pinion so there is no way I can grind it out without damaging the motor mount.
The last thought I have is to put the pinion in a vice and use a tap and hammer to try to punch the shaft down out of the pinion, seems like the least 'dangerous' option. I'm afraid any attempt at just 'prying' the pinion will damage the aluminum mount.
Anyone else have any ideas?
