Kraton Stripped the hub grub screw. Now currently screwed.
I get what you’re saying to break the seal of the loctite, however the screw itself it stripped. No real bite left to turn the grub screw though is the issue im having.
Drill bit slightly smaller than the grub screws. Drill straight and you should be fine. If you Drill through leaving just the threads in place it will back out with a small screw driver. I've done it a few times now.
As a temp fix i ended up knocking out the pin with a tap. Its back in there nice and snug but as you mentioned, parts were inexpensive and they are currently being shipped to my residence :)
Yeah bud, when OM spare parts are readily available and cheap then why waste valuable bashing time trying to fix it :)
Sometimes fixing it is faster than waiting for an order to show up. Sometimes I do both. If I can fix it b4 the order arrives, I'll have a spare part for if it happens again. 😎
