Bumped my Kraton up to 9 punch, and promptly stripped the right rear wheel. When that side strips, it unscrews the locking nut. Lost 2 nuts before I figured out what was going on. So I did the drill bit trick I saw on You Tube. Took a bit, same size as the pin that holds the hex on, and cut one a bit longer, so it hangs out each side, then cut 2 notches in the wheel to match. I'll probably wind up busting the wheel, but it will work for now.
