Where I drive is very dusty and sandy and that’s obviously not good for RC cars but it’s impossible to keep it out of the power module since there is a huge hole in the bottom of it. I bent the teeth on the HR metal Spur gear as well as stripped numerous Plastic spur gears and metal pinion gears. I clean everything with compressed air as much as I can but it’s always broke anyway. I tighten clutch according to Arrma recommendations and I’ve tightened and loosened to see if anything helps but I’m sure it’s from so much dirt.
Would a dust cover help? Does anyone make a sealed power module? Cut a hole in the chassis? It’s so annoying. How can I seal it so dirt won’t get in?
