Don't knowhow does it happen ive only stripped it once
Typically it's one of two things. The first being your gear mesh and second landing from jumps while under throttle.Typhon keeps stripping spur gear any advice??
Thanks
Ok...i think it's the meshTypically it's one of two things. The first being your gear mesh and second landing from jumps while under throttle.
Ok..thank youAlso, check the bearings on the motor. If they go it takes out the spur.
