Maxpayne321
- Talion
This issue is not with my Arma Kraton, but with my Talion. I figure it applies to any RC car. Long story short, I was trying to remove my motor mount on my car so I can fix the pinion gear that came loose, but I could not remove the motor mount screws, being that they are stuck on so tight with Loctite. Anyway, I managed to remove one of the screws, but could not get the others out. I applied so much pressure, that the screwdriver tip broke off in the screw. And now I cannot get the motor mount off. I tried drilling the broken tip out only managed to break two drill bits trying. I even managed to completely strip the other screw. So now there are two screws I cannot get out. Other than destroying my chassis to get the screws out, how can I get them out? Has anyone had this problem? How did you get the screws out? My car is barely two weeks old. I was thinking of calling Tower Hobbies and explaining the situation, maybe they can help?
