- Granite Grom
- Infraction
- Kraton EXB
- Senton 3s
Do you guys have any suggestions on these parts for my k6s to make it indestructible am I missing parts? Are not all of them compatible? You tell me.
I’m going to build this over a couple years my goal is to make my car completely indestructible what parts are you talking about for blingWith all the parts you listed above, seems all are compatible. I would substitute more of the M2C parts where you can. Braces etc. Use PPS center diff parts etc. Skip the Alloy rod ends. Just bling.
You will be replacing almost every single part on the 6s. Correct?
IMHO, many of those parts are just bling. It will look nice, just your rig will become extremely heavy also. Perhaps needlessy so. You don't need all of those parts to make it durable IMHO. But hey, it's your wallet. You are looking at one expensive rig there, with that list of parts. Are you sure you want to put all your apples in one basket? I tend to be more conservative with the bling. And the weight that it brings with no real gain in durability. Remember, added weight makes for more breakage at some point.. Drivetrain load increases exponentially. I would skip all the CF stuff. No advantage durability wise or real weight savings considering ALL the other alloy upgrades. It is just bling.
I'll let others chime in, perhaps more specific.
But go for it if you want.
Just me.
The CF for sure I would delete. I would focus on all PPS, Motor mount, top center cover and support.I’m going to build this over a couple years my goal is to make my car completely indestructible what parts are you talking about for bling
I allready have the rear tower brace and towers just need the chassis and front and rear chassis bracesThe CF for sure I would delete. I would focus on all PPS, Motor mount, top center cover and support.
Delete the alloy shock rod ends. Use Tekno's instead (plastic) Delete the HR wheelie bar set.
I would use CF sleeving over the stock T2T brace instead of using BQ CF one.
I would go with an Arrma EXB compatible Steering top plate. (7075) M2C rear wing mount support at the rear Bulkhead.
Just my ideas. But all this is a personal call. Your wallet.
I am sure it will be one nice rig once it is done. However you do it.
You using this M2C rear tower brace?
With heavy rigs, I feel this is a great option.
https://m2cracing.net/arrma-notorio...tonoutcast-series-rear-shock-tower-brace.html
My 2 cents is to scratch all that hot racing stuff off your list minus 1 hot racing bulkhead with cover. I'll list what I think you need based on my current build and one that's sitting here in parts ready for the build.I’m going to build this over a couple years my goal is to make my car completely indestructible what parts are you talking about for bling
Ya I don't personally Think the front Is neccessary for a hot racing bulkhead. Im installing my first Vitavon bulkhead and like the quality^^^ @dk3000, you said only get one HR bulkhead and cover.
I imagine best at the rear diff???
Yeah I am not a big fan of HR in general, if you have better upgrade brand alternatives to use, where possible.
Think Vivaton (hubs and Bulkheads) and M2C. And a few others.
i killed my kratons front diff case so should I get a aluminum one or stay plastic
Put it on your shelf
+1Run it on 4s and don't jump it, it will never break.
But if you want 6s and send it with bad landings, no RC will be indestructible.
