JohnnyBLX185
- Talion
Hi all, this is my first post, but I've been using this forum as a very useful reference--so thanks everyone!
Today the sun gear on the left side of my rear blew up--Talion v4. Maybe because I was running a 20t pinion and Backflip tires on 6s? The sun gear ended up in 4 pieces and the pin was sheared off.
Anyway my question is do I rebuild the differential, just replace the whole differential (doesn't cost much more), or is there a stronger option than stock parts? I'm just don't know if this was a one off break, or if this is likely to happen again. If I rebuild, should I shim the differential differently--could that have lead to the breakage? Maybe buy a stronger differential case--though that did not seem to be the problem.
For what it's worth, the differential that broke was totally stock, with stock fluid.
Thanks, JBLX
Thanks, JBLX
