So now I got two 50x50mm Hobbywing (HW) cooling fans installed. Why? Because I ordered a HW Heatsink cooling fan combo, which took too long to be delivered (was impatient I know) and bought another combo. Last week I decided to add the second one because it was just lying around. Although two 50x50mm fans look impressive, they only do max 5.300 rpm each according to the specs I found and airflow is a bit weak when I put my hand to the fans.
A bit of research let me to Surpass rocket fans which run on 5v-7,4v and do 16.000 rpm in 40x40mm or 28.000 rpm in 30x30. I got a 150A esc 6v, so I’m not sure how much rpm gain I would see if I would use a small separate lipo. I’m considering getting two 40x40mm or four 30x30mm; the latter would lenghtwise cover the entire heatsink (60mm), and in the width stick out 10mm on each side (not a problem right?).
Does anyone have any ideas / experience on the Surpass rocket fans? On paper the rpm gain looks very impressive and they are not very expensive either.
