@2fast4u thanks for your response. So upper arms positioned away from shock tower with spacers in front? Was going to try 100k/300k/100k on the diffs. Have limited shock travel to pretty much zero at rear but more upfront
@2fast4u cheers. By the way it's not for the Outcast in my avatar pic it's a senton 6s I have. Running a max 8 combo i had 74mph with stock 50 tooth spur and 21 tooth pinion with sweep evo wheels and protoform shell. Just got a 40 tooth spur to fit in centre and will try 23 tooth pinion to start see how that goes
Will do. What sort of difference do you think I can expect from going down 10teeth on spur and up 2 on pinion? Hoping to test tomorrow if possible just final setup to get right this eveningSweet !
That gear change should make a big difference. Post up with your results.
