Hoping to get some ideas as I'm new to the RC world...
Just acquired a 4x4 Senton and my intended use is actually for work.
I will be using this ride as a camera dolly. Essentially I will be placing a GoPro size camera on a 4 foot PVC tube for marketing videography.
As of now, I got the camera mount figured out, but the car tends to sway side to side quite a bit. Also, even with the lightest acceleration, the whole car sways back and forth as well...
With the camera and PVC pole in place the whole rig is rather top heavy, but so far it has not flipped over.
Is there a way to limit the amount of the suspension travel? Are there firmer tires that could be mounted? I'm not using the OEM body at all, so I guess I could put any tires (the wider the better) compatible with this model. I was thinking some larger diameter tires would slow down the take off speed and provide a much smoother ride, which would result in a more fluid video.
Suggestions?
* attaching 2 photos of the "camera rig"
Suggestions?
