mulberryman
- Kraton 8S
Hi Guys
I am after people's thoughts on suspension set up and oil weight, basically I want to get the car as low as possible for fast tarmac runs with road tyres - probably the Louise ones - basically lower than the standard setup will allow me too currently - my ideas where ;
1) what about removing the shock spring ring adjuster - that will give me another 5-10mm , I know the spring would.then rest on the shock cap and it may wear out quicker?
2) shock oil - can someone explain the oil weight system and ratings for me ? Ie. If I out a lower weight in will it sit lower but move more ?
3) springs - again if I put a softer spring on will it sit lower but be more spongy ? I have looked on the arrma website and I can't find any shorter ones just stiffer/softer ?
Any thoughts welcome !
