TyphoonS3
Can I swap my e-brake servo with my steering servo they look the same? Of course then the e-brake would be the new thrott but I don't know if i can reset the controller. They do have different part numbers s652 is my steering servo s650 is my e-brake servo. Also does anyone know a good link to an aftermarket one metal stearing servo that I can put right in without modifying or having to buy additional parts. if so do you have a link to both. This all started when my steering stopped working but my throttle still works it was acting sketchy like it was taking off fast and then it stopped steering I unplugged the steering servo and the throttle seems to be fine now. Also is it worth me looking inside my steering servo or is it just a firmware that they install took a s***?
Oh I just realized if I unplugged the power brakes servo (e-brake) I could just plug it into the other port for the steering servo?Can I swap my e-brake servo with my steering servo they look the same? Of course then the e-brake would be the new thrott but I don't know if i can reset the controller. They do have different part numbers s652 is my steering servo s650 is my e-brake servo. Also does anyone know a good link to an aftermarket one metal stearing servo that I can put right in without modifying or having to buy additional parts. if so do you have a link to both. This all started when my steering stopped working but my throttle still works it was acting sketchy like it was taking off fast and then it stopped steering I unplugged the steering servo and the throttle seems to be fine now. Also is it worth me looking inside my steering servo or is it just a firmware that they install took a s***?
