Hello
I have a Nero and a Kraton.
I run with duratrax onyx 5000 50c and 5400 50c. Arrma recommand minimum 5000 35c, so I'm ok. But all my 6 batteries are swollen. Should I garbage them? What could be the reason? Is that dangerous?
I don't use full trottle that much cause Both are hard to control at full speed and you need some space!
I change balance them each time at 3 amp. (hitec)
I have the speed pinion on each truck. Should I use the slow one? Does the slower one will make the car run longer or shorter with one charge? (Maximum speed is not that important to reach)
I never storage them after each use. Should I storage them each time and rebalance/charge them just before use?
Thank you. I just get in this less than 2 years ago and I'm the only one in my town, so no community around!
