Does anybody else have the Tbone racing rear bumper installed on the V3 Senton? I installed it and hate the way it looks, maybe I installed incorrectly? Any ideas?
Regardless of looks, I like the design of the brace not being attached directly to the bumper. Is it attached to the dif case or a separate block?Does anybody else have the Tbone racing rear bumper installed on the V3 Senton? I installed it and hate the way it looks, maybe I installed incorrectly? Any ideas?
It attaches with the 4 screws used to secure the diff case to the frame on the bottom of the truck. Yea it’s a good concept...it just sticks out wayyyy to far and too low IMO. Didn’t know if this is the way it’s supposed to look...
This is the second post about tbone fitment issues. I don't think I will be buying stuff from them until they get their quality control under control.
If it comes with 4 drilled wholes wich exactly fit the 4 holes in the chassis.. Where you bolt the diff case on.. You did it right.. Cant be mounted in any other way.. I guess you have to live with the way it sits and looks.. Or else.. Dump it in the trash and buy an RPM or POS
@Phein002
Goin through the pictures again.. It seems to me there is a 3 screw/bolt connection between the part that goes under the diff/chassis part and the actual bumper piece.. Those two parts overlap..
Right there in the middle
Is there a way to connect them the other way around? As of now.. The bumper part is attached underneath the diff/chassis part..
What if.. You connect them with the bumper part on top of the diff/chassis part?
In that case you at least raise it a small bit
