- UK..
- Infraction
- Mojave EXB
- Outcast 8s
- Outcast EXB
- Talion EXB
- Typhon 6s
The transmitter is the TTX300 but what receiver are you using in the vehicle? The TR325 that comes with stock Arrma's is only rated to 6.0 volts while the TR326, which also works with the TTX300 is rated to 8.4 volts. So you may have to switch out the receiver to run the Max8 at higher than 6.0 volts.
Iirc all of the Arrma vehicles that came with the TTX 300 also came with the TR326 receiver. My Outcast 6s and my Typhon 3s both came with the TR326.The transmitter is the TTX300 but what receiver are you using in the vehicle? The TR325 that comes with stock Arrma's is only rated to 6.0 volts while the TR326, which also works with the TTX300 is rated to 8.4 volts. So you may have to switch out the receiver to run the Max8 at higher than 6.0 volts.
Edit: I guess they may use the TR326 receiver in the Arrma's. I would check to see which one is in yours and if it's the TR326, you are good to go.
I couldn't remember and honestly have never bothered to look at what came in them. I figured I would give him the information for both of the Tactic receivers that I know about and just have him check the number on it. This way if they put in a different one at the factory or something he isn't mad at me for blowing up his receiver LOL.Iirc all of the Arrma vehicles that came with the TTX 300 also came with the TR326 receiver. My Outcast 6s and my Typhon 3s both came with the TR326.
