- In the stix…NC Mtns
- Kraton 8S
- Kraton EXB
- Mojave
- Senton 3s
Following instructions..... steering to ch1, esc to ch2, power up esc, tx has red light on , push link button.....NADA
Are the batteries in the TX fully charged? If so, then it might be you are too close, or the TX or RX got damaged. I have found with some radios, if you are a few feet away, they connect, but if you are too close they wont.Following instructions..... steering to ch1, esc to ch2, power up esc, tx has red light on , push link button.....NADA
Batteries are brand new....will try some distanceAre the batteries in the TX fully charged? If so, then it might be you are too close, or the TX or RX got damaged. I have found with some radios, if you are a few feet away, they connect, but if you are too close they wont.
Nope, no luck.....last time I buy used....PERIODAre the batteries in the TX fully charged? If so, then it might be you are too close, or the TX or RX got damaged. I have found with some radios, if you are a few feet away, they connect, but if you are too close they wont.
TR 326TTX300 is the transmitter, which receiver are you using?
yep.....may be the problem.....trying a bind plug right now.....last chance for this used rig....It may be a compatibility issue. I have two TTX300 bound to six different TR325’s no problem binding. But I did try the TR326 and had the same problem.
The Tactic TR326 3-Channel 2.4GHz SLT HV Receiver is recommended for use with the Arrma Nero and Tactic TTX300C 2.4GHz 3-Channel SLT Transmitter (TACJ0301).
