Talion 6S BLX
Spar69!
Virginia
  2. Notorious
  3. Talion
OK guys, what temp range is too hot (damage causing hot) for the 6S BLX system???? I'm running stock 13T pinion with Backflips and on a 85 degree day running kinda hard in the yard and on the street for about 10-12 minutes I'm hitting motor temps of 174-182 degrees. How bad is that???
So from what I have read, That's a bit on the warm side. My Talion was running up around 200. Put a couple Yeah Racing fans on it, and that took care of the problem right away. I don't think that 175 is in the dangerous range, but it's warm.
Depending on who you ask, safe max motor temps are somewhere around 170f-180f. Some motor specs say max temp 200f. So if you are running 175f-185f, you are (IMHO) right at the limit of safe temps. Motor fans may be a good idea. Also, The Outcast comes with a 12t pinion so seeing as you are running outcast tires, you may try that gear too.
