Talion 6s,. Fan size that mounts to factory heatsink
FAILWISH
  1. Typhon 6s
I may searching wrong or asking the wrong question in the search function...
I'm looking for a fan to add to the factory aluminum heat sink .. and to piggyback to that question ,how do I connect ,or where do I connect to... reading through all the messages looking at YouTube videos it doesn't show exactly where you connect any kind of extra power accessories. can I connect to extra fan between battery and ESC or does it come with a y adapter to connect 2 fans the one on the ESC and the one on the heatsink together?.. where does the energy come to feed both fans at the same time will I need a y adapter I guess you could say imagine where do I get it from the receiver box?
35mm fan
https://www.amainhobbies.com/team-b...m-cooling-fan-red-bro-tbr-ventuslred/p1333449
There is a lead you can plug right into. All you need is the fan and 4 screws
Plug into here
Hell yeah this is primo info.. what is that plug for out of curiosity?
Its just a built in y harness. Male on one and, female on the other then it goes into the fan
The ESC is a 35mm fan too. Maybe buy two fans, but then you need your own dual female to male y adapter.
That team brood fan is a tornado. It's a little loud but you can't ask for more air from a little fan
Good luck
It is for the motor Fan.
Like you want to install.;)
